Azurelink
May 09, 2022Star
WBC502 Insight Instant Airbridge Zoom calls internet connection unstable
Hi All, I have Internet service extended about 100 feet from my house to an outbuilding using two WBC502 Insight Instant Airbridges configured as a master and a satellite. The ISP is Comcast Busines...
Azurelink
May 09, 2022Star
Yes, I think that is a good ping. Testing off the Airbridge would be more difficult. I guess I could run an ethernet cable down from the top of the barn where the satellite is and take my MBP outside. Is it worth the trouble, if the ping is already good? And what are your thoughts about the transmission power (currently at 15 dBm)?
May 10, 2022Guru - Experienced User
If you're pulling those speeds/ping, its just makes me a little more suspicious of the router is all.
Again, live video's are more sensitive to ping or traffic inspection. Is the Huawei in router mode or access point mode?
Does it happen if you hardwire the pc/laptop into the router?
