plross22's avatar
plross22
Follower
Dec 09, 2021
Compatible with Cisco DNA Center?
We are trying to be able to use the AV Pro line of switches on our campus but our network guys are cisco. Is there a plug in that will allow Netgear switches to be used with their Cisco DNA Center appliance?  Thank you
1 Reply
  • LaurentMa's avatar
    LaurentMa
    NETGEAR Expert
    Hi plross22 ,
    Thank you for posting here. Best would be to schedule a meeting with your IT team and your AV team and us at [email protected], so that we clear out all questions or issues in the first place. Don't worry, we are very much used to that - the NETGEAR AV Line is excellent for the AV portion because it is certified by more than 55 partners already, and we have a dedicated ProAV SE team supporting it. But yes, the AV network should be hooked to the corporate network for control, inventory, management etc. The NETGEAR AV Line is all based on standards including OOB management, SSH, SNMP, and many discovery protocols - even ISDP for certain Cisco networks!
    The Cisco DNA Center will not "configure" the NETGEAR AV Line, the compatibility list at Cisco clearly shows Catalyst 2K and above, only. But the NETGEAR AV Line shall be discoverable and should be monitored using standard protocols like the above.
    Again, we can help build up the case - our IGMP Plus and other enhancements for AV make the NETGEAR AV Line platform a better choice for the AV portion, and yes we can comply to your IT team requirements becasue they deserve it.
    I hope this helps, please reach out to us at  [email protected]
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
ProSupport for Business
