scottdrynan
Jan 25, 2021Tutor
Account Lockout after X Attempts - SRR60
I cannot find out how to set a login lockout after a certain number of attempts. I have been viewing my log files and they are filled with people trying to log in 20 times at least. Since this is a...
YeZ
Jan 26, 2021NETGEAR Expert
We already implemented the feature to lock out the account for 10~15 minutes after a few repeated failure of incorrect username/password. The # of failures is a system level number that applies to every account, not configurable on each account level.
schumaku
Jan 26, 2021Guru - Experienced User
YeZ wrote:We already implemented the feature to lock out the account for 10~15 minutes after a few repeated failure of incorrect username/password.
This is where some DoS can happen (same on the newer Local UI access on the switches btw.), the bad boys are sneaking admin and random or dictionary password attempts over hours or days, and the effective admin (coming from a different IP address typically) remains locked out virtually forever.
YeZ wrote:The # of failures is a system level number that applies to every account, not configurable on each account level.
How many different accounts can exist on the subject SRR60/SRS60? One! It's just admin. No other administrative user accounts can be added my friend.
As I said several times before - the lockout must be based on the source IP - IPv4 and IPv6 - address, not on the one and only default username.
- Apr 16, 2020Retired_Member
