SerLoi's avatar
SerLoi
Associate Sattelite of Kit #2 to Router of Kit ~1
Hello
I Have two Kits SXK80 K1 and K2 with 1 router and 2 satellites in each kit.
K1 works fines in AP mode, K1 Router is connected to switch N3 on our network and the 2 K1 satellites are connected on the same network with ethernet.
I don't want to use K2 Router, but I want to use satellite of the K2 Kit with the K1 Router. But there are set up with K2 Router.
=> How Can I set up K2 satellites with the K1 Router ?
I tried sync with buttons, sync and on the K1 router admin page, but result is the same, Satellite shows magenta color 😞
Have any idea ?
Than you in Advance
Serge
  • BruceGuo's avatar
    BruceGuo
    NETGEAR Expert
    If you buy a kit, Kn satellite is by default paired with Kn router. You have 2 router. You need to note something:
    1. If a SXR80 is under another SXR80, both of them need to be router mode because they will sync internally if one of them is AP mode.
    2. powered on K2 satellite by default will connect an online K2 router. To pair with K1, you need to turn off K2 router first and reset K2 satellite. Make K1 router online, reset K2 satellite and push wps button to wirelessly pair them. Once K2 satellite is connected to K1 Router, K2 satellite will not connect K2 router.
    • SerLoi's avatar
      SerLoi
      Thank you very much for your response  BruceGuo 🙂
      To be clear, my goal is
      - use K1 router, not to use K2 router (maybe I will keep it as backup)
      - use K1 sat and K2 sat connected to K1 router
      - All router and satellites are in the same network 192.168.5.x
      - I want that new computers connected with Orbi Wifi or Ethernet of Orbi are in this same network 192.168.5.x
      - I don't want router starts a dhcp server (and I hope it's not the default) because of conflicts with my actual dhcp server in AD.
      - and obviously, I want that all orbi works in mesh mode with ethernet wired (space between two orbi is to big)
      To make this I will
      - I will switch my K1 router to Router mode (and check if dhcp server is desactivated)
      - K1 router is connected to my network on the switch with Yellow plug
      - K1 sat and K2 sat all connected to other switch on the same network (I have 6 switch connected with fiber)
      - Add each sat (K1 or K2) with Sync Button
      Is it ok like that ?
      must I do something else to reach my goal ?
      Thank you again
      Serge
      • SerLoi's avatar
        SerLoi
        in add, when I checked "Router mode" in the web console, it is written in Help that ALL computers must be connected to the Orbi... but I don't want this, I just want to have WIFI everywhere with the same SSID and let my existing computer connected to my switch...
        And if I buy new satellite, I MUST switch to router mode the router to use it ?
        Sorry not to understand, but I don't want to make a mistake.
ProSupport for Business
