Nickthequick
Jul 14, 2026Initiate
AX600 missing Port Forwarding setting
I have an AX600 in router mode that has been running for multiple years with the same configuration and I had a port forward rule configured that was working on the initial setup. I am trying to edit...
Jul 14, 2026Guru - Experienced User
What model product is this?
Orbi Pro SXK###?
You logging into the routers local web page?
What browser are you using?
- schumakuJul 16, 2026Guru - Experienced User
SXK### are the kit SKU.
The router (where the port forwarding is available) are SXR###
The SXS### are the satellites without port forwarding controls.
Correct, double check you are logged-in on the primary router.
- FURRYe38Jul 16, 2026Guru - Experienced User
Ya I know this. Thanks.
Asking the OP about this...
