Nickthequick
Jul 14, 2026Initiate
AX600 missing Port Forwarding setting
I have an AX600 in router mode that has been running for multiple years with the same configuration and I had a port forward rule configured that was working on the initial setup. I am trying to edit...
Nickthequick
Jul 16, 2026Initiate
SXR80 is the model, I was mistaken. I was trying to find the settings remotely since I wasn't on the LAN at the time via the app and via the online management portal. Still don't see it anywhere. I did find it via the LAN mgmt portal once I was able to be on site
- schumakuJul 16, 2026Guru - Experienced User
Port forwarding config is also available on Netgear Insight, certainly on the Insight Cloud portal:
https://kb.netgear.com/000065750/How-Do-I-Create-a-Firewall-Rule-in-the-Insight-Web-Portal
