Seif's avatar
Seif
Can I connect SRS60 or SRR60 (AP mode) as additional satellites to an RBR850?
Hi, I planning to buy an RBK852, and I happen to have an SRS60 and an SRR60.
Can I connect them to the RBR850 as additional satellites?
Please advise if you know for sure if I can do so.
Thank you,
Seif
  • FURRYe38's avatar
    Not sure if the Pro series is compatible with the Home 8 series systems. I was told my 30 series isn't...
    The SRR in AP mode could be however it would be a separate SSID name using different channels and would not integrate into the MESH system of the 8 series system.
    • DaneA's avatar
      DaneA
      NETGEAR Employee Retired
      Seif,
      The Orbi Pro WiFi 5 devices which includes the SRR60 and SRS60 are not compatible to work with any Orbi Home devices such as the RBK852 and RBR850.
      Also, the Orbi Pro WiFi 6 devices which includes the SXR80 and SXS80 are not compatible to work with any Orbi Home devices such as the RBK852 and RBR850.
      DaneA
      NETGEAR Community Team
      • Seif's avatar
        Seif
        Thank you DaneA,
        Even with wire backhaul? Still not compatible?
        Thank you,
        Seif
ProSupport for Business
