Kayakci
May 17, 2022Initiate
CAX80 and Orbi SRR60 and SRS60
recently upgraded my Netgear router to CAX 80.
but could not connect my Orbi SRR60 to the system.
are they not supposed to work together ?
Mike
Did you connect the SRR system in access point mode?
They don't integrate together but they can work together.
- KayakciInitiate
Thanks for the response however I am not a techy and have no idea what you said.
i basically want them to work as access points
So right now you're in a double nat.
A double nat is when you have 2x routers running in router mode on a network.
What is double NAT and why is it bad? | Answer | NETGEAR Support
So what you need to do is when you install the SRR60, set it up in access point mode.
How do I configure my Orbi router to act as an access point? | Answer | NETGEAR Support
