JDF7
Jul 17, 2024Tutor
Factory Reset fail
Hi Orbi Community, I factory reset my router try to get rid of my old SSID but after two resets I still see them being broadcasted in my known networks. (still connectable) I used to video tutorial...
Jul 17, 2024Guru - Experienced User
Does using the ERASE button on the routers web page help at all?
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
What model Orbi system do you have? I see you tagged a SXS80 series...
JDF7
Jul 20, 2024Tutor
I have the Orbi Pro Wifi 6 SXR80 router and satellite. I can't login into the web control page right now so I used the hardware reset.
