JDF7
Jul 17, 2024Tutor
Factory Reset fail
Hi Orbi Community, I factory reset my router try to get rid of my old SSID but after two resets I still see them being broadcasted in my known networks. (still connectable) I used to video tutorial...
Jul 18, 2024Guru - Experienced User
did you factory reset and/or re-sync the satellites?
I've noticed that if I only reset the router and don't sync the satellites, the satellites will retain the same ssid until that has been done
JDF7
Jul 20, 2024Tutor
Yes i have tried re-syncing the satellite but it fails (doesn't show in the Orbi Insight app)
- FURRYe38Jul 22, 2024Guru - Experienced User
Did you reset both SXR and SXS?
If you ethernet connect the SXS to the back of the SXR, does the SXS get an IP address from the SXR?
- JDF7Jul 22, 2024Tutor
Thank you everyone for all your responses and help. I have the problem solved now. Please everyone have a good day!
- FURRYe38Jul 25, 2024Guru - Experienced User
Please let us know how you got it solved and what worked for you. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
