Re: Help, I can't enter the system interface after changing the SXS80 model to RBS850
My machine is SXS80. I used the [artmtd -w board_model_id RBS850] command in Telnet to change the SXS80 to the RBS850 hardware model. Now the machine is running normally, but the management interface is not displayed, so I can't enter/ The debug.html interface opens the Telnnet option command and changes it back to SXS80. So what I'm asking for now is how to turn on the Telnet function and change it back to SXS80 to make it normal, or restore the default configuration of Telnet.
1 Reply
  • schumaku's avatar
    schumaku
    Duplicating the similar question won't bring you ahead.
    None of all that is a user action as documented. You are fully on your own, converting an SXS80 to and SXR80 (or a vary different RBS850) might require much more changes. Ways off from support - Netgear wont answer your question anyway - and not a subject on what we can assist on here in the Netgear Community. Sorry.
ProSupport for Business
