LarrySolheim
Apr 13, 2021Follower
How to reset an Orbi Pro SRR60
For a few months our Orbi Pro system (SRR60) would not install the latest firmware. Then, after a recent cable company repair in our area, the router was not working properly. I tried the setup as ...
DaneA
Apr 14, 2021NETGEAR Employee Retired
Welcome to the community! :)
Have you tried to connect a PC/laptop directly hardwired to the SRR60? If not yet, kindly try it then check if you will be able to access the web-GUI.
DaneA
NETGEAR Community Team
