hnagaraju's avatar
hnagaraju
NETGEAR Employee Retired
Mar 23, 2021
If your Orbi Pro (SRK60, SXK80) started having frequent client disconnects try this workaround
Dear customers,
We noticed some issues in latest firmware that effects users with specific combinations of configuration.
1) DST enabled
2) Traffic meter Enabled.
There is traffic meter that keeps track of monthly usage stats.
In March  the time changes in middle of month. Orbi pro firmware hit some error that causes instability.  There will be permenet fix for the issue in next MR (Maintiance release).
This "instability in connections"issue is only from
March 14th to April 1st in US timezones
March 28th to April 1st in EU timezones.
and on units running v2.6.2 .200(SRK60 series) and v3.2.3.100 in SXK80
In the meanwhile, please do one of the following as workaround.
1) Set the timer start time to 1:00 and Restart the counter.
at Advance->Advance setup -> Traffic meter
2) Disable DST   at Advance->Administration->NTP settings
Apologies for this inconvenience.
  • The issue is fixed in below FW versions:
    SXK80: V3.3.0.100
    SXK30: V3.2.31.108
    SRK60: 2.7.0.100
1 Reply
  • BruceGuo's avatar
    BruceGuo
    NETGEAR Expert
    SXK80: V3.3.0.100
    SXK30: V3.2.31.108
    SRK60: 2.7.0.100
ProSupport for Business
