brkeogh
Sep 20, 2025Follower
Is AX1800 compatible with AX1800 pro satellite?
Hi! I have an AX1800 mesh setup in my house. I need one more satellite but the AX1800 satellites are only sold in 2-packs or 3-packs. The 'Pro mini' satellites seem to be sold in single packs.
Does anyone know if one of these satellites will work with the 'normal' AX1800 setup? Thanks!
There's a compatability guide for the consumer orbi's: https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
And then the pro orbi's: https://kb.netgear.com/000065558/
you can't mix the pro's and the consumer.
Sure, the Orbi Pro Mini AX1800 kits are made up from an SXR30 (the router), plus two or more SXS30 (satellite[s]).
While all ORbi Pro are EOL, the SXS30 are still available from stock.
Please provide the model number from the label on the bottom of the unit. "AX1800" can refer to lots of different products.
