Farscape's avatar
Mar 08, 2018
No internet through Orbi Pro Satellites (SRS60) even though backhaul status shows "Good"
Have had an Orbi Pro Router (SRK60) and 2 Satellites (SRS60's) installed for less than a week now.  The router and satellites are on firmware 2.1.3.2.  Internet is Comcast xfinity (200Mbps down, 20Mb...
  • wase4711's avatar
    Mar 09, 2018
    what I would try is this:
    have the Xfinity router in router mode, and turn off the wifi part of that router
    have the orbi pro in access point mode
    I have found having the Orbi in AP mode always makes everything work perfectly
    Of course, once you get things switched that way, unplug EVERYTHING, then recoonect the xfinity modem/router first, let it find the internet, then connect the orbi router, let it find the internet, then connect the orbi satalite..
    See if that makes things work they way you want them to
ProSupport for Business
