cmj01's avatar
cmj01
Tutor
Feb 10, 2022
Orbi Pro - rather undewhelmed!
This query relates to SXR80 (router and 2 satelites) which doesn't appear on the model list above...
Have just set this up and feeling a little bit underwhelmed.
I've got it running as a router connected to a Draytek Vigor 130 in bridge mode.
- I thought it had the Amor protection availble - which according to the literature is available for all Orbi mesh systems.... That is rather misleading isn't it? Maybe Orbi Pro should have a different name! Is it planned at all? I've got a free trial of the content filtering but struggling to find out what that actually does...Any details?
- No QoS settings?
- Does it even have a firewall built in?
It seems I should have gone for the Unifi Dream Machine Pro which has threat management and free support! Looks like I might need to add that to get the level of protection I need.
Maybe I'm missing somethign so please let me know if I am.
Many thanks,
Mike
  • plemans's avatar
    The Orbi Pro line doesn't offer amor as most business class setups have their own firewalls/protection and aren't in need of it.
    If its something you want integrated into the router, the Unifi solution might be the better choice. (sad to say)
    I've struggled a bit with all the "add on services" netgear has been selling lately like disney circle, premium parental controls, armor, and game boost. At a certain point, some of the features should be included on systems this expensive.
    • cmj01's avatar
      cmj01
      Tutor
      Thanks for that.. What I was beginning to suspect. I liked the network segregation but I guess I could probably have implemented that on the home series?
      Any recommendations for a good / cost effective firewall / threat detection system?
      Many thanks,
      Mike
      • plemans's avatar
        My home network isn't that complex or needing a ton of security so I make do with off the shelf antivirus/malware and a pi-hole with some aggressive blocking :)
        I've tried the armor but found my solution worked better.
        So I can't give you a decent business class recommendation. Sorry.
ProSupport for Business
