nhinkle
Aug 31, 2018Apprentice
Orbi pro in access point mode dropping RDP connections
I have just installed an Orbi Pro system in my house. It is configured in access point mode with a Nighthawk R7000 acting as the gateway to the internet. The wifi on the r7000 is turned off. I am u...
- Sep 06, 2018
So, I opened a support case. I was put on hold while being transfered to Orbi pro support.
After 40 minutes on hold, I started a chat with Amazon support. Chat was online in less than a minute. In about 5 questions the Amazon rep determined the product was defective. In another 2 I had an RMA and UPS pick up to return the product for full refund. At that point, the Orbi pro support answered the line - barely intelligible Indian accent. After ten questions he wants to remote into my network - that security breach isn't happening.
Solution to Orbi Pro problem = return for refund.
nhinkle
Sep 03, 2018Apprentice
A) all devices have problems, and not just RDP. I have run ping tests and I get wide variablity in response time with about 8 percent packet loss. I have tested this from a windows PC and an android tablet. If I connect using wire to a lan port on the Orbi router, no packet loss or response time issues.
B) not good on other platforms either, they just cope better because the application isn't as sensitive to packet loss. Roku's drop tv streams every once in a while.
C) I reset to factory defaults and reconfigured as access point. This only made it worse.
I have tested with the satellite turned off. Problem still persists.
DaneA
Sep 04, 2018NETGEAR Employee Retired
Thank you for the feedback. Kindly get the logs of the Orbi Pro devices. Here are the steps below:
1. Make sure that both Orbi Pro router set to Access Point mode is on the latest firmware v2.1.4.16.
2. Access http://IP-address-of-Orbi Pro/debug.htm (example: http://192.168.9.1/debug.htm) then click Start capture first.
3. Be sure to save the logs after the issue occurred.
4. Kindly provide a download link (such as Google Drive or Dropbox link) in order for me to obtain the logs when you reply back.
DaneA
NETGEAR Community Team
- nhinkleSep 04, 2018Apprentice
I do not use dropbox or google drive.
Decided not to be recalcitrant. Here is a google drive link:
https://drive.google.com/file/d/1mVfRtCUgtmX1JdcZGnRFakdh4FjK_JHs/view?usp=sharing
