Retired_Member
Dec 09, 2020Orbi Pro SRR60 - DNS Server via DHCP
Hi, i am using a SRR60 with 2 Satellites. (First question, why cann't I choose this System in the drop-down menue as my Model (which is a recommended field). Question : Why is the IP-address of ...
Retired_Member
Dec 09, 2020Does this cause any issues in the real world or in your environment?
Yes, because every DNS request is from the routers IP and therefore a statistic/log is not possible. (pihole)
schumaku
Dec 09, 2020Guru - Experienced User
Retired_Member wrote:Does this cause any issues in the real world or in your environment?
And what are you doing with systems using secured DNS? There is less and less evidence for pihole & Co....
