hencam
Dec 12, 2022Aspirant
Orbi Pro SXR80 disconnects from internet periodically
I am in the UK and connect to the Internet using a 5G modem. The modem shows good signal and doesn't ever drop the connection.
I have the 5G modem set to bridge mode, dhcp, WiFi and routing disabled, and it's connected directly to the orbi. The orbi is getting a valid IP and everything works fine for several hours at a time.
However I've noticed that it continually loses connection to the Internet - the purple light comes on and everything stops working, all the devices are still connected to the WiFi network but they cannot route to the Internet. When this happens the IP the orbi has for the modem changes to 0.0.0.0 - when the orbi reconnects it shows the correct IP in it's place - and as my ISP assigns me a dynamic IP, I can tell it wasn't my 5G connection that dropped as the connection is still using the same IP as before the orbi thought the Internet disconnected (if the 5G connection had dropped I would be assigned a new IP on their network).
If I go to the admin page of the 5G modem it shows it's still connected to the service, in fact it shows some very slight upload traffic from the orbi, but 0 to it.
If I go to the orbi admin page it shows the Internet is disconnected. If I leave it alone it will start to work anything from a couple of minutes to half an hour later. But I can get it working within minutes by clicking on the internet test button on the orbi admin page. This fixes the Internet connection, until it happens again.
My network is really simple, just a modem feeding the orbi and about 25 devices connected via WiFi, and a hue bridge connected by ethernet.
It's really frustrating when it happens during a meeting as I work from home, and is starting to affect my job.
In desperation I've tried disabling DST and traffic monitoring as I saw that had affected other netgear products. It didn't help.
The logs don't seem to show anything helpful, other than Internet disconnected and Internet connected entries:
[DoS Attack: ACK Scan] from source: 18.203.57.224, port 443, Monday, December 12, 2022 23:36:26
[DoS Attack: ACK Scan] from source: 99.86.253.63, port 443, Monday, December 12, 2022 23:35:48
[DoS Attack: ACK Scan] from source: 18.203.57.224, port 443, Monday, December 12, 2022 23:35:22
[DoS Attack: ACK Scan] from source: 52.214.227.89, port 443, Monday, December 12, 2022 23:34:49
[DoS Attack: ACK Scan] from source: 18.203.57.224, port 443, Monday, December 12, 2022 23:34:34
[DoS Attack: ACK Scan] from source: 18.203.57.224, port 443, Monday, December 12, 2022 23:34:18
[DoS Attack: ACK Scan] from source: 52.214.227.89, port 443, Monday, December 12, 2022 23:34:08
[DoS Attack: ACK Scan] from source: 18.203.57.224, port 443, Monday, December 12, 2022 23:33:58
[DHCP IP: 192.168.1.43] to MAC address 20:fe:00:af:6c:57, Monday, December 12, 2022 23:33:41
[DHCP IP: 192.168.1.42] to MAC address 90:23:5b:4a:a1:a7, Monday, December 12, 2022 23:33:35
[DHCP IP: 192.168.1.31] to MAC address f4:b8:5e:c0:68:39, Monday, December 12, 2022 23:33:29
[DoS Attack: ACK Scan] from source: 52.214.227.89, port 443, Monday, December 12, 2022 23:33:28
[DHCP IP: 192.168.1.43] to MAC address 20:fe:00:af:6c:57, Monday, December 12, 2022 23:33:23
[DHCP IP: 192.168.1.32] to MAC address b4:b7:42:cf:54:6a, Monday, December 12, 2022 23:33:17
[DoS Attack: ACK Scan] from source: 18.203.57.224, port 443, Monday, December 12, 2022 23:33:14
[DHCP IP: 192.168.1.30] to MAC address f4:b8:5e:c0:68:a4, Monday, December 12, 2022 23:33:12
[DoS Attack: ACK Scan] from source: 99.86.253.63, port 443, Monday, December 12, 2022 23:33:03
[DHCP IP: 192.168.1.5] to MAC address 00:03:7f:04:2a:42, Monday, December 12, 2022 23:32:41
[DoS Attack: ACK Scan] from source: 18.203.57.224, port 443, Monday, December 12, 2022 23:32:41
[DHCP IP: 192.168.1.5] to MAC address 00:03:7f:04:2a:42, Monday, December 12, 2022 23:32:39
[DoS Attack: ACK Scan] from source: 99.86.253.63, port 443, Monday, December 12, 2022 23:32:36
[Time synchronized with NTP server] Monday, December 12, 2022 23:32:26
[DoS Attack: ACK Scan] from source: 99.86.253.63, port 443, Monday, December 12, 2022 23:32:22
[DHCP IP: 192.168.1.11] to MAC address 44:42:01:35:6f:a3, Monday, December 12, 2022 23:32:20
[DoS Attack: ACK Scan] from source: 52.214.227.89, port 443, Monday, December 12, 2022 23:32:18
[DHCP IP: 192.168.1.9] to MAC address 74:58:f3:7a:c2:73, Monday, December 12, 2022 23:32:18
[DHCP IP: 192.168.1.3] to MAC address 2c:f4:32:21:ea:5e, Monday, December 12, 2022 23:32:18
[Internet connected] IP address: 188.28.167.244, Monday, December 12, 2022 23:32:17
[DHCP IP: 192.168.1.11] to MAC address 44:42:01:35:6f:a3, Monday, December 12, 2022 23:32:15
[DHCP IP: 192.168.1.9] to MAC address 74:58:f3:7a:c2:73, Monday, December 12, 2022 23:32:08
[Internet disconnected] Monday, December 12, 2022 23:32:05
[DHCP IP: 192.168.1.11] to MAC address 44:42:01:35:6f:a3, Monday, December 12, 2022 23:32:04
[Internet connected] IP address: 188.28.167.244, Monday, December 12, 2022 23:32:04
[DHCP IP: 192.168.1.9] to MAC address 74:58:f3:7a:c2:73, Monday, December 12, 2022 23:32:03
[DHCP IP: 192.168.1.11] to MAC address 44:42:01:35:6f:a3, Monday, December 12, 2022 23:31:59
[Internet disconnected] Monday, December 12, 2022 23:31:59
[DHCP IP: 192.168.1.9] to MAC address 74:58:f3:7a:c2:73, Monday, December 12, 2022 23:31:58
[DHCP IP: 192.168.1.11] to MAC address 44:42:01:35:6f:a3, Monday, December 12, 2022 23:31:54
[DHCP IP: 192.168.1.9] to MAC address 74:58:f3:7a:c2:73, Monday, December 12, 2022 23:31:53
[DHCP IP: 192.168.1.11] to MAC address 44:42:01:35:6f:a3, Monday, December 12, 2022 23:31:49
[DHCP IP: 192.168.1.9] to MAC address 74:58:f3:7a:c2:73, Monday, December 12, 2022 23:31:49
[DHCP IP: 192.168.1.11] to MAC address 44:42:01:35:6f:a3, Monday, December 12, 2022 23:31:44
[DHCP IP: 192.168.1.9] to MAC address 74:58:f3:7a:c2:73, Monday, December 12, 2022 23:31:44
[DHCP IP: 192.168.1.11] to MAC address 44:42:01:35:6f:a3, Monday, December 12, 2022 23:31:39
[DHCP IP: 192.168.1.9] to MAC address 74:58:f3:7a:c2:73, Monday, December 12, 2022 23:31:39
[DHCP IP: 192.168.1.11] to MAC address 44:42:01:35:6f:a3, Monday, December 12, 2022 23:31:34
[DHCP IP: 192.168.1.9] to MAC address 74:58:f3:7a:c2:73, Monday, December 12, 2022 23:31:34
[DoS Attack: Ping Sweep] from source: 192.168.69.1, Monday, December 12, 2022 23:31:31
[DoS Attack: TCP/UDP Chargen] from source: 185.94.111.1, port 41238, Monday, December 12, 2022 23:31:30
[DoS Attack: UDP Port Scan] from source: 188.31.250.129, port 53, Monday, December 12, 2022 23:31:30
[DoS Attack: RST Scan] from source: 104.199.65.124, port 4070, Monday, December 12, 2022 23:31:30
[DoS Attack: SYN/ACK Scan] from source: 92.40.248.87, port 443, Monday, December 12, 2022 23:31:29
[DoS Attack: RST Scan] from source: 104.199.240.237, port 4070, Monday, December 12, 2022 23:31:29
[DoS Attack: ACK Scan] from source: 92.40.248.87, port 443, Monday, December 12, 2022 23:31:29
[DHCP IP: 192.168.1.9] to MAC address 74:58:f3:7a:c2:73, Monday, December 12, 2022 23:31:29
[DoS Attack: Ping Sweep] from source: 192.168.69.1, Monday, December 12, 2022 23:31:26
[DHCP IP: 192.168.1.5] to MAC address 00:03:7f:04:2a:42, Monday, December 12, 2022 23:31:19
[DHCP IP: 192.168.1.3] to MAC address 2c:f4:32:21:ea:5e, Monday, December 12, 2022 23:31:05
[DHCP IP: 192.168.1.21] to MAC address ec:0d:e4:41:ba:ac, Monday, December 12, 2022 23:30:52
[DHCP IP: 192.168.1.9] to MAC address 74:58:f3:7a:c2:73, Monday, December 12, 2022 23:30:41
[DHCP IP: 192.168.1.11] to MAC address 44:42:01:35:6f:a3, Monday, December 12, 2022 23:30:40
[DHCP IP: 192.168.1.24] to MAC address f0:0f:ec:7d:47:43, Monday, December 12, 2022 23:30:38
[Internet connected] IP address: 188.28.167.244, Monday, December 12, 2022 23:30:37
[Internet disconnected] Monday, December 12, 2022 23:30:29
[admin login] from source 192.168.1.20, Monday, December 12, 2022 23:30:18
[DHCP IP: 192.168.1.24] to MAC address f0:0f:ec:7d:47:43, Monday, December 12, 2022 23:30:06
[DHCP IP: 192.168.1.3] to MAC address 2c:f4:32:21:ea:5e, Monday, December 12, 2022 23:29:53
[DHCP IP: 192.168.1.9] to MAC address 74:58:f3:7a:c2:73, Monday, December 12, 2022 23:29:34
[DHCP IP: 192.168.1.11] to MAC address 44:42:01:35:6f:a3, Monday, December 12, 2022 23:29:32
[DHCP IP: 192.168.1.5] to MAC address 00:03:7f:04:2a:42, Monday, December 12, 2022 23:29:14
[DHCP IP: 192.168.1.3] to MAC address 2c:f4:32:21:ea:5e, Monday, December 12, 2022 23:28:42
1 Reply
- DaneANETGEAR Employee Retired
Welcome to the community! 🙂
Found out from the NETGEAR Support Team that you already have an ongoing support ticket and its going to be re-escalated to the higher tier of NETGEAR Support. You may want to post the progress of your support ticket here.
DaneA
NETGEAR Community Team
