wifiblues's avatar
wifiblues
Luminary
Jul 22, 2021
outdoor satellite
hi - just purchased the RBK752 and I know that the RBS50Y has to be set up in Extender Mode - here is my question - When I go outdoors after the set up, will the satellite seamlessly carry the wifi signal or will it switch to the Extender network?
thanks...wifiblues
  • plemans's avatar
    it'll depend on your device and its own roaming protocol. The device (laptop/pc/phone) are what decides when to switch between access points.
  • hi all,
    help!
    I am trying to switch the RBS50Y from Orbi mode to Extender mode.  Read and followed the directions several times.  No luck.  It will not switch out.  I recently upgraded to the RBK752 and it is up and running.  Do you think that is the issue as to why the outdoor router will not switch?  I am puzzled and cannot figure it out.
    any thoughts?
    • plemans's avatar
      whats actually happening?
      Did you try factory resetting it and then switching it over?
      • wifiblues's avatar
        wifiblues
        Luminary
        here is a description of what happens -
        I plug it in - in the same room as the RBK752 router - push the sync button - push and release the powerbutton - the bottom lights up white then lights up blue - after i see the blue light - i release the sync - both lights are solid rather than pulsing - after i release the sync button, the bottom starts to try to sync to the router.  now it is pulsing white - after a while it flashes magenta and stays magenta.
        i have reset it a few times.
        any suggestions?
ProSupport for Business
