Neilp2006's avatar
Neilp2006
Problems with images not uploading when connected to orbi pro 6
When connected to my Orbi Mesh system i am unable to upload my expenses to my work system. If however, i connect directly to the router provided by my my ISP it works correctly. Is there a setting that needs to be configured to allow this to work over the mesh?
  • plemans's avatar
    What modem/gateway is the Orbi connected to?
    Is ipv6 enabled?
    • Neilp2006's avatar
      Neilp2006
      It’s a MikroTik h ap ac lite. I don’t know a great deal about it other than it also controls an external 4g broadband receiver.
      • plemans's avatar
        The Mikrotik has its own built-in routing. It's a modem/router combo device. It causes a double nat.
        A double nat happens when you cascade more than one router.
        https://kb.netgear.com/30186/What-is-Double-NAT
        Fixes? There are three options but only use 1.
        1. Put the modem/gateway in modem only/pass-through mode. This turns off its routing functions. If you have it hosting routing features/devices, not a great solution.
        2. Leave the modem/gateway in router mode but put the Netgear IP address into its DMZ. This forwards the data to the Netgear router. You can either leave the modem/gateway wirelessly enabled or disabled. Just make sure it's using a different wifi channel to prevent interference
        3. Put the Netgear into access point mode. This turns off its routing functions. The Wi-Fi/ethernet still works, but it turns off some features. Again, make sure wireless settings are on different channels.
        https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
ProSupport for Business
