BobTRF
Jun 30, 2019Aspirant
Orbi Pro SRR60 wired pps?
What is the SRR60's packets per second forwarding capacity between its LAN and WAN ports, specifically small packets (RTMP uses 128 bytes)?
- Jul 10, 2019
Speaking to engineering about this and based on testing the results were a packet size of 128bytes had a throughput of 100mbps and a packet size of 1460bytes had a throughput of 940mbps. Results may varie depending on current network traffic and cabling.
MrJoshW
Jul 10, 2019NETGEAR Employee Retired
