htgrimmi
May 30, 2025Guide
SRR60 - random Wi-Fi drops
I have an SRR60 with four active SSID's and about 75 devices connected. (A lot of home automation) A couple times a day, the Wi-Fi seems to shut off. Multiple devices and PC's in the house report...
May 30, 2025Guru - Experienced User
Are the devices spread out over all 4 ssid's? Or are you using a Main, IoT, Guest, Random (?)?
Just curious how many are getting loaded onto the 2.4ghz ssid.
Does it matter what band or do all bands drop?
- htgrimmiJun 01, 2025Guide
Not using the guest network but I have all the home automation on the iot. Probably 20-30 2.4 ghz devices.
When it happens, all bands go out.
