htgrimmi
May 30, 2025Guide
SRR60 - random Wi-Fi drops
I have an SRR60 with four active SSID's and about 75 devices connected. (A lot of home automation) A couple times a day, the Wi-Fi seems to shut off. Multiple devices and PC's in the house report...
May 30, 2025Guru - Experienced User
Are the devices spread out over all 4 ssid's? Or are you using a Main, IoT, Guest, Random (?)?
Just curious how many are getting loaded onto the 2.4ghz ssid.
Does it matter what band or do all bands drop?
htgrimmi
Jun 01, 2025Guide
Not using the guest network but I have all the home automation on the iot. Probably 20-30 2.4 ghz devices.
When it happens, all bands go out.
