Dizzallica
Feb 18, 2025Follower
SRR60 breathing/pulsing white and zero connectivity
Down to a last-resort-post here before the router and satellite get junked. Woke up this morning to no connectivity to the router, satellite was still broadcasting SSIDs but had no connectivity ...
Feb 21, 2025Guru - Experienced User
What is the brand and model# of the ISP modem or ONT that the SRR was connecting too?
Usually if the front LED is pink means that the SRR isn't getting a good connected from the ISP modem/ONT. Possible bad cabling. Or the SRR has just failed however seems that if it took a FW load over TFTP, should be ok.
Try the SRR at a different location, say a friend, neighbor or family member and see if the problem follows or not.
