Ayediosmio's avatar
Feb 03, 2022
SRR60 Gigabit Wired Speeds
Wired connection on SRR60, FW V2.7.0.122, Windows PC. I'm only getting 5-600 Mbps download. I replaced an ASUS GT-AC5300 that had stability issues with the Orbi, no other changes to the environment, network, hardware, cables, etc. Even with all other devices connected and using data, I could easily hit 750+ Mbps download through the ASUS on the same speed test immediately before swapping in the Orbi.
I read through a few threads here about speed issues and it always seems to be a discussion about everything but the Orbi device. My setup can handle gigabit speeds, the question is can the Orbi SRR60? Opened a support case and they gave 0 troubleshooting options, kept asking about the WiFi, and in the end are stuck on repeatedly suggesting I RMA the device. I don't want to RMA because I have to ship the existing device back first, and then may or may not receive a new product. I haven't had stability issues thus far so I don't want to go through all that hassle to get a refurb or less stable device.
Is there really that big of a variance in the performance of these devices? Is there any actual troubleshooting to try for improving wired speeds? I'm ready to just live with the slower speed because I'm exhausted with trying to find a decent gigabit mesh router that isn't the price of a 2021 GPU.
  • plemans's avatar
    You didn't give us much to go off.
    You state you replaced your old router that would hit full speeds but had stability issues.
    But then you replaced it and your speed weren't consistent.
    So I'd recommend starting back at basics.
    Harddwire a pc/lapto into the router and tests its hardwired speeds for a period to see how stable the speeds are. NO tmuch point troubleshooting the router if the modem has issues.
    What modem/gateway do you have?
    • Ayediosmio's avatar
      Ayediosmio
      Guide
      I gave the relevant details for what I'm asking
      Correct, by stability issues I mean literally not working. Internet off. Not a slow down in speed, a complete disconnect.
      Incorrect. I replaced it, with the Orbi, and my speed is consistently lower. It is low. Not sometimes fast sometimes slow. The Orbi is slower. Speed test right now is 418 Mbps. I did 10+ speed tests when talking to support.
      This is literally what I did, why I made a post, and why every other thread I've found has not been helpful. The modem does not have issues, it is not new, this is an existing setup where only the Router has changed for issues not related to speed. I had consistent high speeds with my previous router/modem combo, and all that has changed is the router.
      Motorola MB8611 DOCSIS 3.1 Multi-Gig Cable Modem - 2.5 Gbps Ethernet Port
      • JeraldM's avatar
        JeraldM
        NETGEAR Employee Retired
        Hi Ayediosmio,
        Could you PM me the debug logs so we can have our Engineering team take a look into this?
        To get the debug logs, please do the following:
        1. For router, go to http://<ip address of router>/debug.htm, and click "START CAPTURE".  For satellite, find IP address of each satellites from the Attached Devices page, then visit http://<ip address of satellite>/debug.htm, and click "START CAPTURE".
        2. Perform a speed test.
        3. Click "Save Debug Log"
        We may also need to open a support case (if the existing case that you have is already closed) to track this issue further.
        JeraldM
        NETGEAR Community Team
    I appreciate the information and advice you have shared. I will try to figure it out for more.
ProSupport for Business
