5pac3m0nk3y
Sep 19, 2021Aspirant
SRR60 Wifi Bridging?
Does the orbi pro SRR60 offer wifi bridging like, say the WAC 510 through insight? Thanks, Al
DaneA
Sep 20, 2021NETGEAR Employee Retired
The SRR60 is only compatible to work with either the SRS60 or SRC60. The SRR60, SRS60 and SRC60 belong to the Orbi Pro WiFi 5 System. To learn how many satellites can you add to an Orbi WiFi System, kindly check the article below:
How many satellites can you add to an Orbi WiFi System?
If you need WiFi Bridging, I suggest you the WAC510. Kindly check the article below:
How do I set up a wireless bridge (WDS) on my WAC505, WAC510, WAC540, or WAX610 access point?
It might be that you are referring to the mesh network via Insight which the Insight Instant Mesh network. The Insight Instant Mesh network is supported by the following access points: WAC540, WAC564, WAX610, WAX610Y and WAX620. To learn more, kindly check the article below:
How do I set up an Insight Instant Mesh network?
DaneA
NETGEAR Community Team
