SonnyKS
Oct 19, 2019Tutor
SRR60 Wireless2 no internet
SRR60 with latest firmware downloaded.
Set in AP mode with static IP on LAN.
Wireless1 and Wireless2 enabled. Guest SSID disabled.
Clients can connect to Wireless1 just fine and access internet.
Clients get IP if connecting to Wireless2 but cannot get to internet unless check box for "Allow employees to see
each other and access my local network" is checked. But obviously I dont want to have that checked !
MrJoshW Thanks for the offer. Just uploaded new firmware V2.4.1.106 that seems to have fixed the issue.
- AmidalaNETGEAR Employee Retired
According to your description, I verified this version(2.4.0.114) and found no problems. Are you also in this version? Could you please send us the config file?
- davidcheokApprentice
From my own experience, the system takes a while to engage. Leave it for 15-30 mins and see if it works as it should.
- Jan 28, 2022Retired_Member
