TheGrumpyGent's avatar
Dec 20, 2021
SXK80 Networking 101 Question with the Orbi Pro
HI everyone, slightly embarrassed asking this but its been a while setting up VLANS.  I have a couple devices I want to have on a specific VLAN that I plan to wire up (IoT in the Orbi Pro).  Its going to look like this:
Devices -> Unmanaged switch -> Netgear Managed Switch -> Orbi Pro Satellite
If memory serves correctly, on the Netgear Managed switch I will set the port where the Unmanaged switch comes in as VLAN 3 (IoT).  What I'm not sure of right now is the Orbi Pro Satellite.  Presently every port on the Satelitte is set as VLAN 1 (Default), do I keep it that way?  How should the port on the Orbi Pro be set that's connected to the Netgear Managed switch so that it can support traffic for both VLAN 1 and VLAN3?
  • Hi TheGrumpyGent,
    You can change the VLAN profile on each port by going to ADVANCED > Advanced Setup > VLAN / Bridge Settings. From there, you can change either the router or the satellite ports.
    John
    NETGEAR Community Team
1 Reply
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi TheGrumpyGent,
    John
ProSupport for Business
