kdenko
Apr 22, 2023Aspirant
SXR30 Long time to initially connect to WiFi network.
After browsing this forum I could only find one similar post, but they were going from: ISP Cable Modem/Router -> Orbi Router -> and having issues. (Double Routing) They then since but it in bridge ...
Apr 23, 2023Guru - Experienced User
What actual router do you have?
What firmware is on the SXR30 and satellites?
Do you notice if its an issues specific to the router or the satellite connecting?
Once connected, they work fine?
- kdenkoApr 23, 2023Aspirant
NETGEAR Orbi Pro WiFi 6 Mini Mesh System (SXK30)
Newest Firmware is on both.
V4.2.3.102
V4.2.3.102It is noticeable on either or I believe.
Once connected works fine yes. It just takes 30-60 seconds for it to connect in the beginning.- schumakuApr 24, 2023Guru - Experienced User
For the uneducated reader: What makes up the beginning - cold boot the router (connected to the ISP modem)? Cold boot the mesh system (router and satellite)? Wireless client powered on? Wireless client searching for the wireless SSID/name and assign?
Sorry, impossible to provide assistance. The many years old thread referred is more confusing than anything else.
