DavidPits
Jun 21, 2024Follower
SXR30 remote access
I want the ability to remote access my SXR30 router, at least the ability to reset the router remotely. Is this possible?
michaelkenward
Jun 22, 2024Guru - Experienced User
The SXR30 is in a "Pro" device in a class of its own. Unlike most Orbi devices, it does not support the Orbi app. Instead you need the Insight app for whatever remote device you want to use.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Orbi Pro SXR30 | WiFi 6 System | NETGEAR Support
That page will also have any downloads available for your device, including software, firmware and drivers, if they exist.
For more help, try the section for your hardware:
schumaku
Yes, of course: Browse to https://insight.netgear.com/#/devices/dash and mouse-over the device in the list. To the right, you will see a (Restart) button.
