abutlermd
Jul 07, 2025Aspirant
SXR30 Satellite weridness
I was only able to get my SXR30 to sync for the first few weeks after purchase (more than a year ago). By now, at the very least, the firmware is not the same as the router. Anyways, I decided to give it another go, and figured the best place to start was updating the satellite firmware.
I connected the satellite to the router via wired backhaul, then connected my macbook to the satellite via wire, and got web access, so it was at least acting as a switch. As a lark, I tired pressing the sync buttons to see if it would work... no dice, magenta light on the satellite. Insight page doesn't pop up the satellite as a device.
Here's the weird part: if I disconnect the wired backhaul, the macbook (wired to satellite) still gets internet --- I'm using it to write this message right now. Wifi and all other network interfaces disabled. And if I go to "Devices" in the insight app, and subset by "Wired" connections, the port by which my macbook is connected shows as "N/A".
Any explanation? (Or tips on how to get the satellite to sync?)
- abutlermdAspirant
I was unable to figure out the firmware version of the satellite, but I did see something else weird. On the web interface home page, it lists the number of satellites as "1", but under VLan/Bridge settings, it says "No Satellite". And the satellite is listed under "attached devices" but with status "N/A". (Mind you, I write all this while connected to the router only via wifi backhaul -- the only wired connection is my macbook to the satellite).
In addition to the Insight App, the SXR router includes the typical Orbi web interface.
Perhaps it would be helpful to open the web interface and display the Attached Devices information.
https://www.downloads.netgear.com/files/GDC/SXK30/SXK30_UM_EN.pdf
There is also a Firmware Update page that might display the current version of firmware on the satellite.
