brjacobso's avatar
Sep 08, 2022
SXR80 and SXS80 losing connection constantly
Business WiFi Mesh System
latest firmware V4.2.2.130
#SXR80 and##SXS80 pair (1 each
Yesterday, I started losing connection every 10 mins.  The only remedy is either to power cycle the Router or to go to the Basic / Internet page of the router admin portal and hit that "TEST" button.
I thought maybe the latest firmware update was the problem.  It was installed automatically as of 9/3 I believe.  So I downgraded one step back.  This seemed to make it last a few hours before the internet would go out.  But now again, today, it's going every 10 mins.  I went ahead and went back to the latest firmware since that didn't seem to be the issue.
Anyone know what I can try?  I've also power-cycled the main AP for my ISP.  But that didn't seem to help either.
  • plemans's avatar
    You're running it in access point mode?
    when the connection drops, do devices connect but say "connected, no internet"
    Or what error do you get?
    • brjacobso's avatar
      brjacobso
      Tutor
      It's in router mode, but connected to a separate AP from my ISP by cat 7 or 8 cable.  So I get fiber from AT&T, they have the fiber go into their AP box.  I disabled its integrated wifi because I want to use the mesh of these Orbi devices.  Then the orbi has one satellite to help bring the signal to the rest of the house.  I have a couple things wired to the orbi router, but the rest of everything is by wireless to either R or S.
      Correct, I'll be just working on my work laptop, trying to go to a webpage or send messages in various messaging apps like microsoft teams.  Every app that has a way of letting me know they're disconnected starts letting me know, web pages in browsers start going to 'can't access that right now' type messages.
      And then if I go to my phone, I'll get the message "do you want to switch to cellular data or continue trying the wifi?".
      • plemans's avatar
        swtiching off the wireless on the att gateway doesn't disable its router functions. It still leaves you in a double nat.
        If you have their gateway in router mode, try the netgear in access point mode. that'd fix your double nat.
ProSupport for Business
