wayneker
Jan 28, 2023Aspirant
SXS80 LAN port extremely slow
I got Orbi Pro SXK package for home use. Wifi works very well. However, my LAN ports on the satellite has many problems with my Mac mini. I have tried all LAN ports with my Mac mini and the problems are the same.
1. It can not play Netflix without VPN (Netflix error UI3012) while every other devices on Wifi network works just fine.
2. P2P sharing is extremely slow at around 9KB/s at max.
Any idea on how to fix this? Since I am using it for home. I don't need to separate usage/traffic between employees, guests and IOT. Please let me know what to do.
If everything else works fine, I'd be more suspicious of that specific device.
Have a usb--ethernet adapter or wifi adapter you could connect it to and try it with?
- waynekerAspirant
initially, I thought the problem is that device as well.... But It can connect to Internet at around 700-900Mbps. The weird part is.... it takes awhile to "get to" a website, I guess the technical term is ping? P2P is extremely slow around 9Kib/s.... Does the Pro version of Orbi have restricted access to P2P traffic on the LAN port? are there settings to enable P2P traffic on LAN ports?
- hermesromerorApprentice
The satellites are connected to the main router using wire or wireless?
- BruceGuoNETGEAR Expert
Cross-test to narrow down issue.
1. Speed test v.s. P2P test
2. Directly connected to Router v.s. Directly connected to Satellite
3. Use different clients to test or P2P seeds to test
- waynekerAspirant
hi bruce
1 speed test of internet traffic is very fast
2. only have tried to connect to satellite as my cable isn't long enough to reach the router. (I can't move my Mac mini as it is a modified with linear power supply and it's connected to a huge power supply on my audio rack)
3. I have used Transmission and qBittorrent and both are very slow with LAN port. I also tested it with Wifi on Mac mini and it seem the problem is the same? Not completely confirmed as I only tried briefly. Perhaps it's the setting on my Mac?
If testing via wireless or wired having the same problems, I would suggest use another AP to test with your MAC to make sure Mac itself is fine.
Do you have another AP, or use your mobile as hotspot to confirm if the result is consistent. If consistent, it should be Mac problem.
