donalddamato's avatar
donalddamato
The app does not show connected clients
Experiencing same problem & am away from unit, so unable to unplug/replug.   Suggestions?
  • FURRYe38's avatar
    What NG product are you using?
    Insight app?
    • donalddamato's avatar
      donalddamato
      Sorry for my delayed response ---- am using a SXR30 &  Insight 10.0.0 on my Android phone.  (And am still away from the unit.)
      • FURRYe38's avatar
        What FW version is loaded on the Orbi system? Mines using v4.3.4.300.
  • I've  the same FW version ---- 4.3.4.300!   Netgear Employee BrettD claims bug will be fixed in next update --- no release date yet.
  • Thank you very much for your time & thoughts!   If app is updated soon I'll do the reset & setup you suggest the next time I'm back at the unit.
