donalddamato
May 05, 2026Aspirant
The app does not show connected clients
Experiencing same problem & am away from unit, so unable to unplug/replug. Suggestions?
- donalddamatoAspirant
is NOT updated soon
đ
Thank you very much for your time & thoughts! If app is updated soon I'll do the reset & setup you suggest the next time I'm back at the unit.
I've the same FW version ---- 4.3.4.300! Netgear Employee BrettD claims bug will be fixed in next update --- no release date yet.
Reboot remotely for example?
Insight App , tap on the device, bottom left find [Reboot]
That same?
Since Insight update, the app does not show connected clients. | NETGEAR Communities
What NG product are you using?
Insight app?- donalddamatoAspirant
Sorry for my delayed response ---- am using a SXR30 & Insight 10.0.0 on my Android phone. (And am still away from the unit.)
What FW version is loaded on the Orbi system? Mines using v4.3.4.300.
