webmarck
Jan 16, 2018Follower
Usecase for Orbi Pro vs Wac510
I have a small business and own a couple of insight managed switches and are looking into extending the solution with option for wireless access for the employies. But with the annoncement that Orbi ...
- Jan 21, 2018
I just want to follow-up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
DaneA
Jan 21, 2018NETGEAR Employee Retired
DaneA
BretD
Jan 25, 2018Administrator
Additionally, the Orbi Pro is tri-band (meaning 3 WiFi Channels) and uses one band as a wireless backhaul, instead of an Ethernet backhaul on the WAC. This means, placement of the device can be very flexible, while still maintaining very high WiFi bandwidth for connected clients.
