Wiley1's avatar
Wiley1
WAX220 Issue (moved from the Orbi section)
I'm having the same issue with my WAX220.   My laptop can see many SSIDs in my neighborhood but not mine.
Firmware is up to date.  I've tried changing the 2.4 channel, the power level, the bandwidth, and yes, I've tried turning off the AX function in the WAP.
And, why is my WAP transmitting a Hidden Network when I have not configured my SSID to be hidden?  I am not able to connect to it manually.
The wireless card in my Win10 laptop is a RealTek RTL8188CE with the latest driver I can find.
Are there any setting changes I can make there that might help?
  • schumaku's avatar
    schumaku
    A complete different system from the ORbi SRX30 discussed where you had necroposted. Will request a moderator moving your post to the dedicated community section on the Business Essentials Access Points to discuss NETGEAR Business Essentials Access Point Series, including WAX200 models like WAX202, WAX214, and WAX216. That's done herewith....
    Is this WAX220 a newly delivered and installed system? These come with a 60 days after your purchase, you are eligible for complimentary phone and email technical support from NETGEAR experts for installation and basic troubleshooting. You may need your original proof of purchase and the product serial number to receive this service.
    Can't see why a standalone WAX220 should bring special hidden SSID into the air. My WAX220 here for sure doesn't. The only potentially unexpected network on air on a WAX220 is the Management Interface, by default active for about 15 Minutes after system boot - however, this can't be configured as a hidden network.
    Convinced you really talk of a WAX220 here, with the current WAX220 Firmware Version 1.0.3.5 installed?
    The Netgear APs with the additional hidden SSID are more systems with simplified Mesh capabilities, like the WAX6xx or WBE7xx models. It's not possible to connect to these hidden network - lack of known security details - on the Netgear Pro WiFi APs.
    • Wiley1's avatar
      Wiley1
      When I log into the support page, it tells me my device is EoL.  That's why I'm asking the Community.
      Yes, I definitely have a WAX200.   Yes, the Firmware is current.  I updated it from 10.0.3.4 yesterday.
      I know the Hidden Network signal is coming from my box because I can see the decreased signal strength on the laptop when I reduce the transmit power to "half" or "quarter".
      Maybe a factory reset should be my next action?
ProSupport for Business
