Anonymous
Apr 01, 2020Armor on Wifi 6 Routers
Hi, I've just bought the Nighthawk RAX80. Are there any plans to activate Armor on the Wifi 6 models? You would have thought so with the cost of them. If so, what's the timescale?
Many thanks
I know they plan on rolling it out to the RAX devices at some point. but I don't know when and netgear doesn't release dates. To many different things impact release dates such as bugs or world issues (covid).
- AnonymousDo you know this for certain? If it’s in the pipeline I’ll keep hold of it. The thing is, Asus and TP-Link have Trend Micro variants on their Wifi 6 routers. There is no antivirus software included for Mac and PC admittedly but, to be honest, a router level only Netgear Armor would’ve suited me better.
Do I know 100%? No, I don't. Is it a reliable revenue stream for netgear? Yes it is.
From my experience, they get the basic firmware running decent and then add features.
- ShawnmAspirantIs Netgear armour being planned for CAX80 modem router?
- plemansGuru - Experienced UserI'd imagine so since its a revenue stream for netgear/bitdefender. I know its been added to some the RAX devices (higher end) . The CAX80 was the most recently released device and its usually a bit after rollout that armor gets released.
- ShawnmAspirantDo u think it’s better to keep my cable company’s modem Putting it in bridge mode and get the RAX version instead so that I can have it? Would I lose any features by not going with the all in one?
