Elisern's avatar
Elisern
Having all kinds of problems with my 8 month old rbr760 and my 3 month old cm 3000 modem.
Why not just share with all of us?? :-/
  • FURRYe38's avatar
    What problems are you having on the CM modem and Orbi system? Need more details here.
    You can set up any Orbi system with out having Armor. Just factory reset the RBR and setup from scratch with a wired PC and web browser:
    Orbi Systems Manual Factory Reset Process | NETGEAR Communities
    If Armor is disabled, then it's disabled. Or enabled. It's apart of FW and can't be removed.
    For the CM modem:
    Which ISP are you connected with?
    https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-modem-router
    Please post a copy and paste of the modems connection status and event log page.
    https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
    https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
    On the Orbi system:
    Is IPv6 enabled or disabled?
    Using ISP detected DNS or custom DNS?
  • Having all kinds of problems with my 8 month old rbr760 and my 3 month old cm 3000 modem.
    Just to save some repetitious pandering...
    1. My ISP has been out twice and nothing wrong.
    2. Both my cat 6a and coax cables are all brand new.
    3. Firmware is up to date.
    4. Both the router and modem have been fully cycled many many many times to get them back working again (because they keep crashing...I can see the errors in the logs).
    5. I HAVE FACTORY RESET BOTH multiple times but everything still intermittently drops.
    6. Darn Armor which was never wanted says it's active, but I have it disabled.
    As  all of you here may expect...NetGear customer support was USELESS.  Hard to understand reps and I was the one who had to suggest review of event logs, I was the one asking about channels..  basically the rep didn't have a clue.  The customer 'lack of' support rep was just short and kept trying to push it on the ISP  who had already been out twice.
    Now I am trying to get the darn Armor software off of the router even though it's disabled because it caused Havoc on my last orbi when I accidently added it and wondering if that is the issue.  I work from home and this has wrecked havoc on my work day for a week and a half.
    Here we are... and as typical Netgear is responding behind the scenes with who knows what advice about the Armor and how to get it off instead of just sharing with everyone
