sreeni_n92's avatar
Aug 27, 2019
When will the Armor will be implemented for Nighthawk R8000P
When will the Armor will be implemented & available for Nighthawk R8000P ?
(I see its available for R8000 models now)
  • Its availble on the R8000P now (1.4.1.42) - I just installed this FW a few weeks ago and ignored its prompt.  You can purchase BitDefender outright, no need to go through Netgear for it.
    • myersw's avatar
      myersw
      Master
      Have run BitDefender for years on PC's and MAC. Never an issue, just works and protects. Keeps coming with more extensions for browsers to cover more possibilities of bad folks trying to do something. They also make a box that sits between the modem and router if you like the sounds of Armor. I am not sure how much additional load Armor puts on the CPU in the router, that would be a concern of mine.
    • cfansoon's avatar
      cfansoon
      Guide
      I don't think R8000P can activate Armor, otherwise why netgear's website does not list it under their Armor router list? while R7000P is listed along-side  R7000.
      If R8000P can activate Armor, I will go to my local computer store to purchase it immediately.
      I went to my local computer store yesterday, they have R8000P and R8500, but don't have R8000.
      They said R8000 is an old model, R8000P is newer, they are not going to re-stock R8000.
      • AbhayB's avatar
        AbhayB
        NETGEAR Employee Retired
        Hi all,
        I am the PLM at NETGEAR for R8000P. We are, at this point, actively working on Armor support on R8000P - it's in external beta and QA phase. We hope to roll it out before end of the year. We will be testing it to make sure there's no loss of performance.
        Thank you for your interest.
