Jawnoble
Nov 07, 2017Aspirant
34 character system generated admin username for R7000
I ran through the set up program I got . xxxxxx is where I've replaced the actual text , so I'm not broadcasting my passwords. But Look at the Admin Username. ! Trust me I did not create this.
I read several posts about how impossible it is to change the username. Well it's been changed. How do I change it back. The Genie andriod app doesn't allow Admin to be changed , so I can't login to it.
Output from the setup :
Congratulations!
You are successfully connected to the Internet.
2.4G Wireless Settings:
2.4GHz Wireless Network Name (SSID): xxxxxxxx
Wireless Network Key (Password) xxxxxxxxx
5G Wireless Settings:
5GHz Wireless Network Name (SSID): xxxxxxxx
Router Admin Settings:
Admin User Name: $1$DCpdW29G$ls.9oTo.DtNGkNxDAZ9mQ0
New Admin Password: xxxxxxxxxx
- William10aMaster
Can you log into the router via a wired lan connection then you could access the routers gui without using the mobile device. Are you the the admin users name you said the devices has is not used by the device and not the router.
- JawnobleAspirant
Yes I can login in through a broswer, but I would like to use the app. The app's login screen won't allow the user name to be changed., so i can't login with a name other thatn admin.
