elmatero's avatar
Apr 11, 2022
Can't log in to Nighthawk app (R6400v2)
Hello. I Have problem with login to Nighthawk app. Everything was working normally suddenly app has asked me for router password and won't accept this password. Replay is: Logon timed out please try again. If this issue persists  try rebooting your device.
Device (phone) was rebooted - doesn't help,
Cash of android Nighthawk App cleared -doesn't help
Clear all data of app - doesn't help
Uninstall/Reinstall app - doesn't help
Restart of router - doesn't help
Reset router to factory setup - this help me but this is not acceptable solution.
Today Nighthawk app second time didn't accept my password and reply with above message.
Do I have reset to factory my router every two weeks to get this app working?
Please fix it.
  • plemans's avatar
    Your not the first we've seen with issues on the app.
    Most resort to just logging in through the browser.
    • elmatero's avatar
      elmatero
      Tutor
      I'm paying for Netgear Armor and the only way to enable or disable this service is to use Nighthawk app.. that's why i need it.
      • plemans's avatar
        If its causing an issue with using armor, you can go through support as well.
        To get a hold of support for subscriptions services like Armor/Circle, click on "MyNetgear" at the top.
        Register an account (or login) and then the device.
        From there you can start the support process.
        Click on: My Support---->Contact Support---->Get help with my subscription service
  • michaelkenward's avatar
    michaelkenward
    What is the firmware on the router?
    Firmware and app operations are closely linked.
    • elmatero's avatar
      elmatero
      Tutor
      Router firmware is: V1.0.4.126_10.0.102
      Nighthawk Appversion is: 2.15.1.2104
        michaelkenward
        That is the latest firmware for the R6400v2. Your first message said R6400. That's different hardware.
