dlucas10
Nov 03, 2017Follower
Circle loses Premium
Hello!
I have the Circle setup, and it seems to have lost the premium features. When I’m in the Circle app, and I restore iTunes purchase it says it can find the subscription but when I look in iTunes subscriptions it says it’s active and will renew December 1. Thoughts?
- Turns out I had an active Circle GO subscription, instead of an active Circle Netgear Premium subscription ( I don't remember exactly when I started Go, but might have been on initial setup of the Circle app). The 2 subscriptions aren't hard to confuse with each other in the Google Play app. Anyway, when I re added the Netgear premium subscription all the normal functionality came back.
- DexterJBNETGEAR Moderator
- harlannorthAspirant
I'm having the same issue with the R7000P -- if I try to buy it again I am told that the recurring purchase already exists, if I try to find it can't find my purchase.
Is there a solution?
- vegenigmaAspirant
Hello, I signed up for Circle Premium and after rebooting my router, the Circle App no longer identifies me as a premium subscriber. Is there a solution for this?
-Scott
