dlucas10's avatar
dlucas10
Follower
Nov 03, 2017
Circle loses Premium
Hello!
I have the Circle setup, and it seems to have lost the premium features. When I’m in the Circle app, and I restore iTunes purchase it says it can find the subscription but when I look in iTunes subscriptions it says it’s active and will renew December 1. Thoughts?
  • Turns out I had an active Circle GO subscription, instead of an active Circle Netgear Premium subscription ( I don't remember exactly when I started Go, but might have been on initial setup of the Circle app). The 2 subscriptions aren't hard to confuse with each other in the Google Play app. Anyway, when I re added the Netgear premium subscription all the normal functionality came back.
  • Hello, I signed up for Circle Premium and after rebooting my router, the Circle App no longer identifies me as a premium subscriber.   Is there a solution for this?
    -Scott
    • WaterlooStu's avatar
      WaterlooStu
      Tutor
      Same issue here ... This has been going on since end of December. I'm still being billed, but app doesn't show premiun subscription. Still shows the little blue guft icon on top right.
      I'm just finally getting a chance to find a solution.
        WaterlooStu
        Tutor
  • I'm having the same issue with the R7000P -- if I try to buy it again I am told that the recurring purchase already exists, if I try to find it can't find my purchase.
    Is there a solution?
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi dlucas10,
    I have sent you a message. Please check your inbox.
    Dexter
    Community Team
