ninja661
Jan 29, 2018Luminary
Genie App on Windows 10 FAIL
Wondering if anyone else has had problems with the latest edition of the Genie app for Windows 10? I have tried it, the installer launches but then I get errors about missing DLL files and a whole sl...
antinode
Jan 29, 2018Guru
> the Genie app for Windows 10? [...]
Everyone who's tried it?
https://community.netgear.com/t5/x/x/m-p/1496338
Assuming, of course, that your "the latest edition of the Genie app
for Windows" is equivalent to this:
http://updates1.netgear.com/netgeargenie/update/NETGEARGenie-install.exe
- ninja661Jan 29, 2018Luminary
That is the little beasty that tried and failed numerous times - any fixes? Just wait until Netgear replaces it or ?
- antinodeJan 29, 2018Guru
Why would it do anything different the second time?
Not my software. Trying to reverse-engineer what might be a bug or a
corrupt kit sounds to me like a waste of (my) time. I have enough
trouble with the web-browser interface on these things, so I've never
bothered with would would seem to be one more layer of unreliable
(Netgear) software.
- whdevlApr 08, 2018Aspirant
I had same isssues. Simple fix everytime. Open the download folder to locate file you downloaded, right-click it and select run as administrator.
- ninja661Apr 09, 2018LuminaryTried that and still same problems - router vs app device lists are completely different no matter if the app or programs are removed, reinstalled. I have even tried the “Nighthawk” app which gets closer, but not quite there, Sorry but running as admin is not the answer at least on this router.
