vic_the_hic
Jul 25, 2016Aspirant
Genie bypass account not working on all devices
I can login into my by pass account on all devices and bypass parental controls.
However on my Galaxy S7 it says Im logged in as ... but the parental controls are still active as wont let me see various blocked sites even though I have set the bypass account to minimal.
It works fine on my Galaxy S3 and windows 10 and XP
Tried Support again.
Had to create test account and try with that then tried on a diferent phone. Eventually he gave me the Beta version of Genie which works fine on my device.
Should have cut to the chase and given me that at the start especially since he admitted that lots of other users have the same problem and the Beta version is the fix.
Told me it will be rolled out in the next few days.
Thanks Netgear for fixing your own product.
(Call took around 90 minutes)
- doraemonProdigy
What device are you using? Do you use the same os on the S7 as the S3? Maybe try to power cycle the phone.
- vic_the_hicAspirantHi, thanks for reply.
Not sure what you mean by device. I'm using an S7-edge which uses marshmallow as the OS, which is different to what the S2 uses.- doraemonProdigy
Which netgear device? Your S3 is using kitkat?
- vic_the_hicAspirantI would think so but I'm not home at the moment so can't check. I think my router is R7000, the one with three antennas
- doraemonProdigy
I see. Better submit a case to support. Might be an issue with that marshmallow os.
Thanks but Im way past their stupid 90 day limit plus theres no way Im going to shell out support for a fault with Genie which should be tested/updated to work with all devices.
- GLOTutorHi,
I came across this thread as I was having the same/similar issue.
I tried creating a new Test bypass account and logged in using the new credentials on a device (not the one with the issue). It still didn't rectify the problem. So I deleted all my bypass accounts.
In the end I got past it by : jumping on my windows PC and signing into Netgear Genie. I then went into Patent controls and changed the access from Bypass to 'Default Router Setting'
This was the only way to get around it as all my IOS and Android devices were indicating that i had to remove the bypass account first. Even though the MacBook and Smart TV and network switch never had a bypass set up on them.
Hope this helps someone. - vic_the_hicAspirantTry contacting Netgear to get the Beta although I was told by them that it would be released in a few weeks
