Jejskj's avatar
Jejskj
Tutor
Jul 17, 2017
Netgear genie pause internet not working
Just installed NGenie app today on ios10.3.
Unable to "pause internet" for another iOS device connected to my wifi, using the Network Map. Even though the "Pause internet" toggle is ON.
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Jejskj and Geneticjim,
    1. What is the model number and firmware version of your device?
    2. Have you tried using another device (Android, another iOS)?
    3. Have you tried uninstalling and reinstalling the app?
    Dexter
    Community Team
    • Jejskj's avatar
      Jejskj
      Tutor
      1.Model WNDR3400v2
      2. Yes, installed app onto iPad, no luck
      3. Yes, I uninstalled /reinstalled app, no luck
      I also rebooted the router.
      • ljc2007's avatar
        ljc2007
        Tutor
        I am having the same issue. The app shows that the selected device is paused, but in reallity it is not.
         I have also completed all the suggested tasks.
        IPhone OS 10.3.3
        Model # WNDR4500v2
        firmware version V1.0.0.60
        genie Version 3.1.28
  • Firmware version V1.0.1.40_1.0.68,   some devices can be paused and one in particular cannot.  it is an ipad being managed by our school system with MDM. tried with both ipad Genie and PC Genie. it will allow the block command however an immediate refresh shows it is not blocked/paused.  the device is on the 2.4ghz network and still works.
  • Same issue as of today November 27 2017. I just bought the Orbi and I can not pause the internet for the connected device
    • Kac0025's avatar
      Kac0025
      Initiate
      Genie ver 3.1.36
      1.0.1.46 firmware
      Pausing internet no longer works,
      This is a must have option with kids.
      • phod2's avatar
        phod2
        I have the same issue since upgrading to the latest firmware v1.0.1.28
