llalonde
Oct 31, 2015Initiate
Netgear Genie unusable on Mac
Hello Folks,
Netgear genie is unstable on a Mac (El Capitan). I cannot quit the application once I've finished using it.
I have to do a 'Force Quit' to kill the application.
Anyone have a fix for this?
Thanks!
- DexterJBNETGEAR Moderator
- brieTutor
why not post public solution? i had a similar problem too but just killed the app via terminal as any net.geek would do. bigger issue unable to find anywhere is how to UNINSTALL the (cr)app? i assume the installer is adding all sorts of daemon-ic detritus, so simply dragging to trash can't be enough. please help & add to genie FAQ or manual!
- fradanInitiate
Same here (running latest version of Genie on Yosimite 10.10.5).
Have to force quit every time to get out of app and enter password multiple times.
How much longer before a fix?
Thanks
- dtraczInitiate
I had the same problem had to force quite ,also my desktop picture changed to El Capitan.
Any fixes?
- jasonhuntInitiate
Me too!
- suelovesdcInitiate
I have the same problem - please help!
- koko125Aspirant
I am having an issue with it as well. Mine won't even launch. I get a message that the installation was successful but when I launch the app,I get "You can't open the application "NETGEARGenie.app" because it may be damed or incomplete."
Hi koko125,
This issue has already been reported and engineering was already made aware. Rest assured, we are working on a fix and we do apologize for the inconvenience that this has caused you. Please keep an eye out for the next update for possible fixes.
Dexter
Community Team
- skydevilaceAspirant
Having a problem with Netgear genie on iMAC using Yosemite. Need to log in multiple times. Also need to force quit after using. Have downloaded several times to no avail.
Hi skydevilace,
This issue is already being looked at and worked on by engineering. We do apologize for the inconvenience. Please do check for available updates for the app.
Dexter
Community Team
- DanzjenInitiate
I have the same problem, cant qoit the program on El Capitain
I have this exact same problem and its driving me crazy.. it also changed my background pictures. what is the fix?
- MFMiltichAspirant
That's my issue as well - having to use Force Quit to terminate the Genie application. It has been that way for years for multiple Mac OS versions/Genie versions. I reported this about a year ago and have not had any meaniful response. Because of this, it makes me concerned about what else the application isn't doing properly.
Thanks.
- MFMiltichAspirant
Thanks.
- pbbraunInitiate
I have a netgear ex 7000 extender. I have had trouble getting my Mac computers to airprint to my MFC7840W. Your office has helped me via a telephone call but now once I load Netgear Genie it crashes and I get a screen that says "Netgear Genie Quit Unexpectantly.
It was working until today.
