AMCL's avatar
AMCL
Guide
Sep 28, 2017
NETGEAR USB Control Center macOS High Sierra
Hi everybody,
After updating to macOS High Sierra, USB Control Center stopped working.
It complains about “installation could not be completed” and suggest a reinstallation, but neither a reinstallation nor a fresh one work.
I wonder if I am doing something wrong or maybe High Sierra is simply not supported yet...
Could you please help me? Thanks in advance!
  • I am having the same difficulty, and suspect that everyone ungrading to High Sierra will find that the Netgear USB Control Center is dead in the water. Is it perhaps not a 64 bit application?
    Hope that the Netgear folks understand that this is a general problem for many thousands of users, and will try to upgrade it for us.
  • I have the same problem. Now to wait (forever?) for an update?
  • Having the same issue on MacOS High Sierra . Tried uninstalling and installing again but in vain . Following error if i try manually from console ,
    /Applications/NETGEAR/NETGEAR\ USB\ Control\ Center.app/Contents/MacOS/NETGEAR\ USB\ Control\ Center ; exit;
    [Info] Software Version: 1.02.71
    2017-09-29 11:10:06.830 NETGEAR USB Control Center[68096:1199139] Mac Version: 10.13.0
    2017-09-29 11:10:06.830 NETGEAR USB Control Center[68096:1199139] main
    2017-09-29 11:10:06.831 NETGEAR USB Control Center[68096:1199139] GetIPAddressesByOTA
    2017-09-29 11:10:06.831 NETGEAR USB Control Center[68096:1199139] MacIPAddress=127.0.0.1
    2017-09-29 11:10:06.831 NETGEAR USB Control Center[68096:1199139] MacIPAddress=10.67.120.34
    [NetUSB] IOServiceGetMatchingServices err: 0
    [NetUSB] IOServiceOpen err: 268435459
    NetUSBInit() failed!
    2017-09-29 11:10:06.837 NETGEAR USB Control Center[68096:1199139] ThisLanguage: en-IN
    /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.1.1/Common/ChunkCompression.cpp:50: Error: unsupported compressor 8
    /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.1.1/Libraries/CompressData/CompressData.c:353: Error: Unknown compression scheme encountered for file '/System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/Exceptions.plist'
    /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.1.1/Libraries/CompressData/CompressData.c:353: Error: Unknown compression scheme encountered for file '/System/Library/CoreServices/CoreTypes.bundle/Contents/Library/AppExceptions.bundle/Exceptions.plist'
    [Info] Mac Version: 10.13.0
    2017-09-29 11:10:06.926 NETGEAR USB Control Center[68096:1199139] [Info] Mac Version: 10.13.0
    PlayToPC = 0, PlayToWAA = 1
    WAAThreadStart Start
    Please give a fix soon..
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi all,
      Let me check on this.
      Dexter
      Community Team
      • westanney's avatar
        westanney
        Ok thius is starting to get really irrating.  I have four computers, three have High Sierra and since I purchased my router three years ago I cannot even contact support without paying.  Can someone from NetGear please inform me how I can get anything that will work with High Sierra.  That or boxing day sales are coming in a couple of weeks.  If I replace my router, it will not be with a NetGear router.  I hate to be like that but.....
